Results 1 to 3 of 3
    Meath
    Default Re-building an SR engine for s14a
    Well lads iv a few questions! I want to do a huge spec re-build! So the questions are will a s13 180sx engine fit in the s14 with the bulk head as it doesn't have the taper on the rocker cover? Second one if changing all internals could a use a NA engine is it only a matter of taking plugs out of the block for the oil and water feeds to a turbo or do I need the DET engine to start with!
    Dont use an NA engine...Block has to be bored and tapped etc for oil feed...waterways and spray nozzels... Expensive to do
    Dont use a 180sx block either...This will mean wiring a new loom and changing inlets etc...
    Just use your own engine or get a good s14 block
    Meath
    Well that just answers all my questions thanks!
