well lads , I know this might be a stupit question but i just wondering is there any differences in the rb 25 in spec 1 and spec 2 r33 and if there is witch would be the best ?![]()
meant to be looking at a 33 next week so would be also very very interested to know the difference too!!
Taken from another site:
Exterior, Series 2 is
1) Front Bumper more 'edgy' in design, different Indicators and driving lamps
2) Headlights, Similar to the Spec 1 but slimer in height and look more rectangular
3) Grille, its lost many of the slats found on early spec 1 and more like a GTR design grille but more 'closed' design than the GTR
4) Bonnet is totally different as the lights are different and has more of a droop to the leading edge of the bonnet to fit in with the new grille
5) More pro-nounced bonnet bulge lines
6) This model has an option chin spoiler
Some other minor things, apparently there are minor mods to the rear spoiler (i've never noticed this tbh) also the rear "skyline" panel is body coloured and the sliding flap over the boot lock also changed from a gel coated smooth type to an embossed Nissan logo.
Interior:
-New style Steering wheel, (also common to R34)
-New style trim on seats, more of a patterned cloth trim as opposed to the Spec 1 Velour type trim.
-Passenger Side Airbag, (this was however an optional extra on late Spec 1 cars, but quite rare for Spec 1 cars.)
-Differently covered and slightly changed design of the dash fascia panel, gone was the rubberised finish and a new 'crackled' finish which was more hard wearing. Notice the new style 'bulges' around heater vents, hazard / rear demist buttons and clock.
-Different warning light clock surround design, Spec 1 had a more open design, Spec 2 has circular warning light design.
-Spec 2 have a seatbelt runner (Drivers side only) that extends from the B-Pillar to provide a better driver comfort
As the Models changed over from Spec 1 to Spec 2 at the production factory some late 1995 Spec 1 GTST had the improved Spec 2 engines and its seems some may even have got the Spec 2 interior seats and trim panels also.
This is very feasable as Nissan would want to use up all the parts they had some some cars exibit a mixture of the 2 specs.
Whilst were on about Spec 2 engines, there are some differences between the two:
-Turbine Inducer (Air Intake) wheels, Spec 2 is Nylon Spec 1 is Steel
Please Note: All R33 GTST Exducer (Exhaust side) Wheels are ceramic.
-Cam shafts are different and are not inter-changable between engine specs.
-ECU is diffently mapped - so i'm led to believe, but with different turbo spool times and different cams then i guess it would of been.
-Spec 2 have different clutch setups, but are basically the same.
_Spec 1 engine has an coil / spark ignitor unit located on top of the motor at the back on the rocker cover near the firewall, whereas the Spec 2 has the ignitor built into the ECU.
-Late Spec 2 also have a different CAS unit
-Throttle Position Sensor is different also
-Air Flow Meter Unit is different, has a pink label
Series 2 is a much nicer and aggressive looking car, series 1 looks rounded and soft.
Very good series 2 for sale: http://driftireland.com/forum/showthread.php?t=27960
Cheers Davy for that info ,im not really looking for a R33 i was looking for a rb25 running gear and was wondering was there any differences between the spec 1 rb25 and the spec 2
Can I ask something as well cose no point to start new thread
Is suspension same as turbo and non turbo version ?
