Results 1 to 10 of 10
    do you know dave o leary? ask him if you do as he put a r32 2 door running gear in his 4 door skyline
    Senior Member grange's Avatar
    i dont kid is he on this?
    team ball bag
    id say they are the same lad, mine was auto so never had a manual prop and i put an sr20 gearbox in it, if you can measure the length from the back of the box to the 2 carrier bolt holes and the total length from box to diff i will measuar the 2 door one i have here, but i recon they will be the same!
    Quote Originally Posted by grange View Post
    think his user name is s15 spec r on here
    cheers gem and nikki
    team ball bag
    Exactly the same prop
    Like R32s? Check out R32 Life!
    http://r32life.blogspot.com/
    tis exactly the same prop dude..i done the conversion on daves(s15 spec r) one it'll fit no problem
    yeah man it will fit the finest, just make sure if your car has an abs diff you get an abs prop, as they are different lenghts
