Did you use a Consult and Timing light to sync the Ign timing ?
Robbie
i lined up the dot an knotch on the cas and put it back in while everythin was at tdc.then i used a timin light on it. the power im down in low revs is well noticable.any idea where i went wrong or is it normal?
