Results 1 to 10 of 19
Thread: Turbo Troubles!
    di Member MrMagoo's Avatar
    Mar 2011
    Default Turbo Troubles!
    Hey Folks
    I blew the Greddy t517z turbo on Sunday at Tynagh, Was driving great, then all of a slap no boost, no smoke, just no power.
    Pulled into the pits and checked it out, huge thanks to Carrigtwohil Auto Centre and the lads, helped pull off the Induction Kit and get at an inspection plate (or something, not sure really!) Opened the plate on the turbo up and could get at the shaft and blades, and there was massive play.
    Question is, I dont want to put a new turbo in and an underlying problem that caused the first on to go rears its ugly head and another one goes!
    What could have caused the turbo to let go the way it did! ie no smoke just no boost.
    Cheers Boffins!
    Eoin
    Mar 2011
    Hmm amyone have any ideas??
    Sr, Lad!
    Most likely reason would be oil starvation to the turbo,
    are the lines flowing freely delivery and return?
    di Member podgedun's Avatar
    May 2010
    Carlow
    have u got oil pressure gauge?? first thing to go if ya have low pressure would be turbo...
    Mar 2011
    Oil sender was leaking so the previous owner disconnected it, First thing is to get that sorted to see the reading, and check the oil feed line to make sure its not clogged.
    Anything else to look out for??
    Apr 2012
    check oil pressure when you get that fixed same happened me and it shit the big ends week after so get it checked;
    Cork, Ireland
    Just stay away from the fins with a Pliers!!! Doesn't help.................!
    TEAM MANFOOT
    Oct 2011
    Dundalk/newry
    Where u running big boost? The bearings in the turbo went from just wear I'd say.
    di Member keith-n's Avatar
    Apr 2011
    Bandon
    This. Turbo was already on way out IMO and as previously said by the seller IIRC.
    Saying that, turbo issues and me wouldnt be the best of friends.
    Team manfoot : Its all about the 1Fourty8
    Mar 2011
    @ Sean180, thats what Im hoping, as witht he massive shaft play (hehe i love saying that) and lack of smoke of any real sort, I hope the bearings collapsed! Ill be checking oil pressure and the oil line to turbo to make sure no blockage!
    @ Keith, I think he said there was a small bit of play in shaft, but with the floating bearings in these turbos its apparently acceptable!
    He he look at me, sounds like i know what im saying! Havent a clue just repeating what the expert said!
