Results 1 to 10 of 16
    Default R34 rb26 Conversion.....
    Hi guys,
    Im just about to undertake a rb26tt conversion to my r34 gtt,the meat and bones of the swap im pretty confident with,whats making me nervous is the wiring,any suggestions on who might be able to do that side of it if i get stuck? cheers.....
    Depends what part of country u from lad, Will the gtt gearbox bolt straight up to her?
    Quote Originally Posted by Clockworks View Post
    Hi guys,
    Just get the complete wiring loom from a 34 GTR and you shouldn't have any probs.
    It will run the engine etc properly and all the secondary system like climate control etc are the same between GTT and GTR
    Quote Originally Posted by nissan_doctor View Post
    Is there not a conversion harness available now for changing at the bulkhead on the 25 to convert to the 26?
    Quote Originally Posted by ae86f20c View Post
    All skyline boxes fit all RB engines
    Quote Originally Posted by Mick K View Post
    No that I've heard of but like I said It wouldn't be needed. There is no factory connector on the bulkhead anyway, it all runs in to the ECU.
    @clockworks: Don't forget you'll need to modify the sump on the RB26 aswell.
    Thanks for the input guys;
    and please excuse my ignorance,(I`v been avoiding wiring for as long as i can remember) do you mean the complete loom(inc all dash wiring/including such things as radio,switches etc) or just the wiring that enters from the engine bay to the ecu?
    The rb26 engine is currently fitted to a converted r33gts, this one..(http://www.driftireland.com/showthread.php?t=2282) which i bought as my donor car on tuesday! could the loom from the r33 be used or should i start looking for a r34 one, believe me i`ll be greatful for any and all advice on this one ..........cheers.
    Pro Driver
    i have a r34 skyline here with r33 gt-r running gear.buy this save ya doing
    the conversion lol
    You see the probs will arise depending on what car the RB26 came from.
    If the engine came from an R34 GTR and you got an R34 GTR loom from the engine to your ecu then thats all you would need.
    Since you have bought a car that is already a conversion it would be near impossible to say without working out what way the wireing was done before.
    only if you take my own R34 gtt against it carpo!
    .....would the wiring issue be something you would take on,nissandoc?
    I could have a look alright. Have you already started stripping your car or what stage are you at?
    Easiest thing to do would be fit the engine and loom from the r33 you have and then see if it runs and if not trace the problem then.
