Results 1 to 5 of 5
Thread: amature drift
    Member
    Jan 2012
    dublin
    Default amature drift
    how do i go about entering the amature drift or signing up who do i get intouch with
    di Member twailbait's Avatar
    Quote Originally Posted by buggykarl View Post
    As in the amateur class of Prodrift? I presume you have a track ready car and all the gear then?
    Member
    Jan 2012
    dublin
    yes amature pro drift yes ive a s14 sr20det their nearly ready to go so how do i go about it and wat do i need
    di Member sandstorm's Avatar
    May 2010
    monaghan
    Only 2 things really..
    1. If your car is up to spec then you will need to get it logged. i believe its Brendan Stone doing it this year, so at this point im guessin you will have to make arrangements with him to see the car and inspect it.
    2. You will have to register yourself with Prodrift and get a licence number and livery for the car. Contact Sarah Hegarty at the PD office and she will sort ya out..
    all the info you need is here>>> http://www.prodriftseries.com/2012/0...-registration/
    Its also a good idea to print off the complete rules & regulations and tick off each one so as you are sure YOU and the CAR are up to standard BEFORE making contact with the PD office..
    they can be found here>>> http://www.prodriftseries.com/ireland/rules-regs/
    Good Luck
    "I don't have to be careful, I've got a gun!"
    Homer Simpson...
    Member
    Jan 2012
    dublin
    lovely ill get onto brendans father i do a bit on their track already so ill ask them about it thanks a mill
