Results 1 to 9 of 9
    di Member pinny's Avatar
    Mar 2011
    Galway
    Default Fitting hydro on bmw question
    Theres 2 lines going back from the servo to the rear vs the nissans having one.
    Im thinking of using a t joiner to join the 2 into one then run this single line to the hydro.
    Single line back out of hydro to another t joint connecting to the back brakes.
    Has anyone done this ?
    Im thinking itl be fine, just double checking
    SM Vehicle Services driftfan's Avatar
    Ballymoney
    yeah that should be fine i think, as i have to do that with mine but i think mine might have 3 lines but im not sure so will have to check...
    Junior Member chris byrne's Avatar
    Jan 2012
    whitechurch/ ratfarnham
    hears how i did my handbrake in my e30! ran it back to a joiner an straight to the back wheels easy stuff lads
    RK.MOTORSPORT.TEAM
    i didnt bother cutting the two rear lines and t piecing them, i ran a line from the master cylinder to the hydro and from the hydro to the rear port on the abs pump. its working perfect and seemed like less hassle.
    Mar 2011
    Galway
    Quote Originally Posted by kev.skyline View Post
    i like this idea !!
    you will have to take out your abs relay if you do it that way, abs stops it locking if you dont. i found it difficult to find the right fitting for the master cylinder, ended up getting them in ashgrove interparts in dun laoghaire, he ordered a box of them as i got the last 2.
    Mar 2011
    Galway
    Just to give this closure i plumbed it the way i said first - 2 into 1 - into hydro - back down from hydro - 1 into 2 !
    It also bled quicker than any nissan !
    Ballymoney
    checked mine and it only has 2 lines so ill be doing the same then
    Mar 2011
    Galway
    Quote Originally Posted by driftfan View Post
    2 x t pieces
    2 x connections for your hydro
    3/16 copper pipe and your sorted
