Hi i've a 97 180sx originally a DE now a det blacktop non vvti, it sound as if its running on 3 cylinders , i've replaced the spark plugs, afm, coil packs from a running sr20, re timed the engine, compression test checked ecu, injectors(standard), fuel pump etc, sum idiot cut the wires going 2 the fuel pump relay in engine compartment and joined them up different seems 2 be no advantage , also to get the fuel pump to come on when u turn on ignition theres a black wire earthed to a bolt beside dr seat? now when i start it up which is no problem doing, it runs roughly, but if i pull out the fuel pump relay it ticks over perfectly but will not rev up??? What could be wrong? the previous owner told me it had a red top but that went bang they fitted this blacktop but i wonder if they changed the loom and ecu? he handed me 2 other ecus with it when i bought it... finally he had no intercooler of any description on the engine it was piped straight across like a de! i've since fitted a front mount and pipes and the lambdas wires are broken off it so i could need a new 1 of them or would it make any diff? Any suggestions welcome
Cheers
