Results 1 to 10 of 13
Thread: 180sx problem.?
    cork
    Default 180sx problem.?
    my 180 is running like shite! the last few weeks when i got to about 4000rpm it chugs and will stay chugging until around 5000 rpm and is ok then but not perfect? today it was spluttering all the way through the revs and is almost cutting out when i come to a stop at traffic etc. i dont have any cover over the plugs and since i put the vented bonnet i was thinking it might be something getting wet? i also put in new plugs recently but maybe their not gapped properly? dont really know whats wrong but its wrecking my head and its my daily so im afraid of doing any damage by driving it so any help appreciated!
    Feb 2011
    cork
    did u check fuel pressure lad,
    also check for boost leaks
    Member
    Feb 2012
    dublin
    could be coils failing is it like a misfire?
    if u aint first...your last. SHAKE N BAKE!
    coils,boost leak,fuel pump,afm,loose connections on ecu???
    cork
    Quote Originally Posted by mattybyrne2008 View Post
    could be all the above! did it all myself so god knows what ive done! how would i troubleshoot each?
    cork
    Quote Originally Posted by antokwon View Post
    ya a serious misfire!
    it could be 1 of soooooo many things man i had same problem with my driftcar and only found the problem latley....has it got a walbro pump or uprated injectors??
    cork
    Quote Originally Posted by joey banana s14 View Post
    ya has a walbro alrite bud. totally forgot bout the avcr stuff too. ill sort that out this week if i can. up the walls at the moment.
    cork
    Quote Originally Posted by s13/180sx View Post
    how do i check for fuel pressure?
