Results 1 to 10 of 10
    di Member flynhy's Avatar
    Jan 2011
    Dublin
    Default Help with my PFC!!!
    Hi lads, I need help. I've been stupid and connected wrong wires going into my PFC. One of the resistors (at least I think this is how it's called) is gone and I don't know where to find one. I need it fixed by next Thursday as I'm booked for mapping in tdp and I don't want to miss my slot. There is a picture of the board and the resistors that is gone. I need as much info for that resistor as possible .
    Thanks
    cork
    wheres the picture?if its just a resistor,then the coloured bands on it tell you the value in ohms
    di Member pepsterx's Avatar
    Mayo
    Ahahahahahah
    Jan 2011
    Dublin
    Sorry i was at work and the pictures were too big to upload.
    Jan 2011
    Dublin
    I went to Maplin and they didn`t had a clue what exactly it is. Then i went to Radionics and they said that there is a few types of them resistors and told me to find a diagram of the motherboard and see what exactly is the resistor.
    cork
    what wires did you connect wrong?looks like coilpack or injector
    MEATH
    Can you not just take one out of the stock ecu? Better off just getting a nistune at this stage . can't see this working well for ye
    Jun 2011
    If you've connected something wrongly enough to blow a resistor chances are you've damaged something more critical too. Soldering on another resistor aint gonna lose you anything tho. Looks like they're all 22 ohm resistors (http://www.hobby-hour.com/electronics/smdcalc.php) so go find a mate that's handy with a soldering iron!
    Jan 2011
    Dublin
    I got it fixed lads. Droped it to a laptop shop and they new straight away what resistor is and fixed it for 20 min. It`s back in the car and working.
    I stupidly connected reverse electrical flow circuit to coil pack 1 while trying to relocate the the fuel pump pun.
    Mayo
    ahahahaha
