Results 1 to 8 of 8
    di Member s14sideways's Avatar
    Dec 2009
    CO,DONEGAL
    Default s15 air bag light??
    does anyone know how to fix the airbag light,the airbag light keeps flashing?im putting on a after market steering wheel to,need the light to work normal for the nct !!!
    will this thing on ebay work??
    click
    http://www.ebay.co.uk/itm/1-8-ohm-re...item4aaf374836
    Jan 2011
    cork city
    2 ohm resister lad into where the air bag was conected too.
    http://forum.s15oc.com/showthread.ph...t=airbag+light
    Here's the process to reset the air bag light.
    Open driver door
    Get in
    Shut door
    Turn ignition to the on position (all the way, but not to start car)
    Open door
    Reach down with your right hand
    Press the door ajar sensor button thing (7) times (10 worked for me)
    Shut door
    Start your car.....
    This should reset the airbag lamp.
    Skids & Wheelies
    Waterford
    I took out the bulb And passed the nct and no annoying light on
    Moonlight Kids™ dil's Avatar
    May 2010
    Kerry
    wire to oil light?
    Team Nocturnal 20vees's Avatar
    Feb 2011
    cork
    no light will fail nct unless you got lucky , 2omh resistor( about 20cent in maplin or such a place )push it into the plug for the air bag sorted ,and the door sensor needs to be pushed 7times within 10 seconds for that to work..next time do a search this topic is brought up at least once a week even though its been covered loads of times and really sucks balls
    Click on the picture please like and share our page thanks
    di Member Dotzs14a's Avatar
    Dubland
    Quote Originally Posted by peteconneely View Post
    Open driver door
    Get in
    Shut door
    Open door
    Shut door
    Start your car.....
    That worked for me to but not sure with an aftermarket wheel
    ive aftermarket steering wheel and it works for me
