Results 1 to 10 of 14
    di Member haydn itr's Avatar
    Dec 2010
    Default Problem with bleeding hydro
    Have the hydro fitted and bleed it , used the guide off drift works can't link Cas I'm on the fone ! But I have perfect brakes but no hydro ! Basically u open the bleed nipple then put the brake down slowly hold it down then pull back handbrake slowly and hold it then close nipple and leave them off I repeated that but still no hydro any help ?
    Jun 2011
    bleed dem at da calipers, 2man job, pull da handbrake few times den hold it on nd open da nipple on da calliper, close it b4 ya let off the hydro nd repeat til ders no air each side!!
    Get one man bleeding kit (saves losing all ur fluid) you'll need someone else its a two man job! and just keep at it, can take 5 mins or 5 hours lol..
    pump brakes hold down then pull hydro hold both and release nipple, lock up and release hydro first then foot peddle, and just keep at it really, always works on mine and tommys car that way, doesnt take too long either somehow
    Dec 2010
    I was bleeding it at the calipers ok
    I'll just keep at it as long as I'm at it the right way
    di Member pinny's Avatar
    Mar 2011
    Make sure your pumping the pedal before holding it and opening the nipple. Pumping will force the air pockets down the line
    Dec 2010
    But would I not have shit brakes if I had a lot of air that what is confusing me
    Quote Originally Posted by haydn itr View Post
    Another thing that might help ya is to have the car running, if its full of air your brakes will be crap
    Dec 2010
    is there pressure on hydro just not locking wheels or wat ? is it a 1.6 mx5 ?
    Dec 2010
    Ye and ye Darren !
    Dec 2010
    its not bleeding prob so the calipers are shocking in them yokes you can modify front starlet calipers onto the back of them easy anough. then youl have a savage hand brake
