Results 1 to 9 of 9
    Senior Member ste's Avatar
    north dublin
    Default sr20 high idle ???/
    lads the drift cars idling at near 2k even when warm, the cars got no restrictions at all in exhaust just straight pipe and i removed thermostat recently too, would this be affecting the idle or any ideas on how to get it lower
    cheers
    West Limerick
    Theres a screw on top of the idle control valve on the inlet manifold that will control the revs..
    north dublin
    cool so just wind that down a lil
    Any vacuum pipes off or split?
    with that stat out is the car getting warm enough? as when its cold it will idle high and with that stat out it mite b staying cold signal back
    north dublin
    water takes while to go up ian but cars had thermo out a while and temps were ok but idle has been high since fitting the exhaust i think
    belfast up north bai
    dont just wind the screw out of the idle control valve as said check all the vacum pipes for splits and make sure the throttle cable has a bit of slack seen this before
    make sure the throttle body flap is closing right there is a diafram below it thats controled with water temp sometimes the stick which hold the flap open
    Team Nocturnal 20vees's Avatar
    Feb 2011
    cork
    idle air control valve closes when the engine is warm so warm up is taking too long or not at all with the thermostat out, do you have a water temp gauge whats that saying ? should be around 80degrees .
    Click on the picture please like and share our page thanks
    Junior Member
    Apr 2012
    Is she low on water? had 4age which water pump was startin to leak and when water got low it started to idle high and slightly hunt a bit....other than that if its after happening all of a sudden has to be air gettin in somewhere?
