Results 1 to 10 of 10
    Mar 2011
    carlow
    Default BMW heads help needed
    rite lads i basiclly wanna know the difference between the 525 24v engine and the 523i engine as a guy is looking to px a 523i car for something that i have but i was looking for a 525 24v engine for a project so basically wanna know whats the difference
    i"ve heard that the 525 24v are suppose to be 190bhp and the 523 are only 140bhp
    can someone please clear up the do"S and don"ts for me asap as i need to deal over the wkd
    any help is greatly appreciated
    thanks in advance
    Jul 2010
    Westmeath
    There restricted on power from 2.5 with small manifold easy change but
    There nearly a cert to overheat, any one I've had that's a 2.3 has cooked
    Mar 2011
    carlow
    ah i"ll keep looking for a 24v so
    cheers for feedback
    Cork
    I've a 24v here, steel blck non vanos. Only catch is the loom is cut before the exuberant do I've no ecu for it
    ecu* was on the phone, must have autocorrected
    Wicklow/Dublin
    There identical engines apart from exhaust system and intake mani restrictions cousing 523 be only 170 bhp wheres 525 is 190 although as said before very easy to go back the proper 190 brake by changing mani and exhaust
    p.s. both are 24valve m52b25
    Thread Rapist!!! Diesel-Dick's Avatar
    Aug 2010
    Dungarvan, Co. Waterford
    as said above really, and the 525 are an m50 with steel block, 523 are m52 with alloy block
    Cork, Ireland
    Bmws will give u mental breakdowns!!
    TEAM MANFOOT
    di Member keith-n's Avatar
    Apr 2011
    Bandon
    Quote Originally Posted by gtrslider View Post
    Your doing it wrong
    As said above, their the same thing more or less. You can make changes to bring it to same power reletivly easily but hen why buy something to change for same effects....
    Team manfoot : Its all about the 1Fourty8
    Cork
    Wouldn't say a M52b25 (523) engine is pointless over a M50b25 as it has its advantages.
    the M52 with the M50 inlet and chipped to suit makes more power than an M50 too. Other big plus is the engine is alot lighter which helps.
    What I would say however is... Why bother when you can get an M52b28 from a 328 and potential for an easy extra 50bhp and alot more torque
    Quote Originally Posted by Chuck_g View Post
    why so ive had them for years with little to no hassel unlike the nissans.a few light mods electric fan etc stops overheating problems
