When you buy your off the shelf products to increase lock whether it’s from DW, Nengun or RHD Japan they are designed for the cars original geometry so what have you done to correct the issue of changing that ?
well as i found out sunday at drift fest you dont want a wider track at the back than the front because front end grip will be shit, i made the front wheels a wider track and problem solved front grip better,
hope this bit of info helps you on your quest
