Results 1 to 3 of 3
    Default External wastegate/boost controller problem maybe?
    Right who knows about external wastegates, basically just given the R32 a very short blast before mapping and it seems to be boosting crazy. I let off when it went to 1.6 Bar! I am running a Turbosmart wastegate on the stock manifold with an electronic boost controller, I have the boost feed coming off the intercooler pipe work and going to the boost controller solenoid and then from the solenoid ...to the bottom port on the wastegate, I have the top port just open to atmo. Does all this sound OK?
    I had the boost controller set to off and it boosted crazy and then turned it on and set it at like 2 which should make it boost fuck all but it still went up to like 1.6 Bar? This makes me think that either my boost controller isin't working or my external wastegate isin't opening?
    Sorry for the essay but got mapping on Thursday with TDP so need to sort this, is it even a problem or am I just getting worked up over nothing?
    http://r32life.blogspot.com/
    Site Trader: TDP - Trackday Performance
    Quote Originally Posted by driftescort View Post
    It sounds like you have it plumed it up arse ways.
    I will draw you a diagram in a min and post it up.
    What make boost controller have you ?
    Robbie
    Quote Originally Posted by robbie@tdp.ie View Post
    Robbie
    That would be great Robbie thanks!
    Its a Blitz Dual SBC.
