well lads, i no front hubs use a 14mm pitch an rear use a 13mm pitch, is that the same for 4 an 5 stud? like are s13 4 stud rear studs the same are s14/ skyline? cheers lads
ah right so the 14.3mm taper ones are eaiser get than the rear 13.1mm? that why u drilled them out?
