Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
  1. #11
    di Member jap scrap's Avatar
    Run old fuel pump straight off the battery check its running then check the relay for it plug gaps sound like a lot of your problem or as said above bad earths just stick an extra few on you might bypass the bad one
  2. #12
    Sr, Lad!
    Boost pipes ok?
    Also Is the fuel rail, filter and reg connected in the right order?
  3. #13
    Sr, Lad!
    If its an earth I'd say it would most likely be an individual earth from the engine/ecu loom somewhere - even one big engine earth strap should have it running.
  4. #14
    check the ecu the caps are known to go in them also did you try a tps sensor in it
  5. #15
    belfast up north bai
    is it vvti or non vvti if its vvti and may help u any ive the standart ecu out of my jzx100
  6. #16
    It's a non vvti I've tryed three Ecu's 3 map sensors and two ignighter
    What's a tps sensor
  7. #17
    The fuel pump is working coz when u turn on the ignition the fuel pumps starts and you can feel it in the return pipe il try sticking on a load more earths I found out last night how to get flash codes so il try that tonight and see what faults show up
    Keep the ideas cumn lads as I'm running out at this stage
  8. #18
    Senior Member Dori_Rory's Avatar
    Letterkenny, Co.Donegal....the land of buns and donuts
    Quote Originally Posted by babyeater690 View Post
    What's a tps sensor
    Throttle Position Sensor
  9. #19
    I changed that aswell lad I'm really thinking its in the loom at this stage dose anyone know what wires had to be changed to put the 1j in the tezz I know there only a few but I could start there and work my way threw the loom
  10. #20
    All cly tested last night and all 155 to 160 psi so there perfect so its in the wireing or a sensor dose anyone know what the wireing mids are for the 1jz into the tezz so I can check all connections
