Results 1 to 10 of 20
    Member
    Aug 2011
    Exclamation 1jz problem ** Please Help**
    I put a 1jz into an Altezza and I had it running on Saturday but it had a slight misfire, yowdi did this for me and he is a top man but had to go away so I thought I'd check it out myself.
    I think its in the wiring somwhere or a sensor, I changed every part you can think off related to it injectors coilpacks maf sensor cam sensor even an injector and its still not working. I can't do the bleep code because the clocks are the original Altezza ones.
    I was told I could put a wire into W and connect it to a bulb and count it that way but does anyone know what else it could be or is there anyone that would be willing to give me a hand checking it out today. I'm in Drogheda.
    The car was suppose to be getting sprayed today so need to get it sorted ASAP so any help I'd really appreciate it.
    make sure the spark plugs are gaped right between 0.8 0.6 might sort it for ya.
    the car wont even start now just pops and bangs its like the timing is off but its not its perfect and its not 180 degree out either im running out of ideas now
    cork
    it could be overfuelling
    did you check the condition of the plugs
    e.g. black,brown,white,wet etc.
    JZ For Life! Greg's Avatar
    Boost pipes ok?
    Senior Member Dori_Rory's Avatar
    Letterkenny, Co.Donegal....the land of buns and donuts
    Bad earths ccould be another one. was the engjne running all right in whatever car it was takin out of?
    Member
    Aug 2011
    Yeah was running fine in the donor car
    Sr, Lad!
    Boost pipes ok?
    Also Is the fuel rail, filter and reg connected in the right order?
    Sr, Lad!
    If its an earth I'd say it would most likely be an individual earth from the engine/ecu loom somewhere - even one big engine earth strap should have it running.
