Results 1 to 10 of 17
Thread: Rb20det
    Default Rb20det
    has a RB20DET have a standard boost solenoid? If so where is it located?
    Iv a aftermarket HKS EVC 4 boost controller,set it up & programged the boost settings as per the manual says. Iv it set to .85 bar.
    The car isnt boosting anymore than .7 bar tho. So only thing i can think of is there is a standard boost bontroller in the engine that is restricting it or else i need a adjustable actuator? Different views have been on this, some say i need a adjustable actuator and others say the standard one should be good for .85.
    bump...nobody on here has no knowledge to answer this no?
    No...
    Quote Originally Posted by Cooldrft View Post
    No...
    Thanks is the standard actuator limited to .7 bar?
    Yea, think .7 is a stock rb20 actuator.
    You must have that boost controller piped up wrong. you dont need a adjustable actuator when you have a boost controller.
    Get some pics up.
    Get some pics up.
    When you say i dont need a adjustable actuator & the standard is .7.. do i disconnect the actuator then so the boost controller will do all the work? I followed the instructions & they where fairly simple, but the standard actuator is still hooked up...
    Man I hate boost controllers....! Sell it and use the ajustable actuator...!
    Quote Originally Posted by DaveZigen View Post
    It takes no talent, sacrifice or commitment to be a critic. Fact!
    Sr, Lad!
    Is it a dsbc spec s or r?
    Should have done that in the first place
    Quote Originally Posted by 2tonne View Post
    now where getting technical... its black? its a while since i looked at it now...
    Agree
