Results 1 to 7 of 7
    di Member Darenm's Avatar
    Sep 2010
    Default difference between hks fcon and nistune??
    Was talking 2 Dil earlier and got me thinking
    What are the difference between the 2?
    Is the fcon just as good?
    Just looking for options before I go get a map done
    When I have all the bits
    The HKS is a better ecu
    It runs a map sensor insted of afm
    I cant think of the terminology but it has a larger "bit"
    The detail of the map basically can be tuned better and more finely
    Someone will come and give the correct account soon
    di Member dude's Avatar
    Aug 2010
    mayo
    you should get on to robbie in tdp hes very help full and will go trough all your diffrent options for diffrent ecus and explain everything you want to know
    [SIGPIC][/SIGPIC]
    Quote Originally Posted by Frankae86 View Post
    depends totaly on what model f-con it is, a v-pro gold is the best one, there is also an f-con IS and SZ,
    if i had a v-pro id use it but if not id get a nistune
    Moonlight Kids™ dil's Avatar
    May 2010
    Kerry
    good thread daren this will make my mind up too hopefully!
    Sep 2010
    Well Dil gem seems 2 put it in 2 play there all depending on which fcon we get get the rite 1 and its worth our while if not nistune is calling
    To be blunt everybody would love a 530D but if we could afford & justify it we would have an M5. Pretty much the same differ.
    WWW.WKDIMPORTS.COM
