I have been told the R33 gearbox is good for up to 1000bhp. After talking with Mike Deane he has swayed me into going down the road of a 350z gearbox. Way better ratios. The gaps in the R33 are to big between 2 to 3 and 3 to 4.
Fast cars are only as fast as the boys pushing them for you!
I had completely forgot about this thread. So a year on and I have finally fully polly bushed the car which was badly needed and powder coated as much as possible.I discovered the sills were rusted out so I had those replaced and the underneath body shultzed. Replaced all the worn out suspension arms. I went and got some wider 10.5j wheels for the rear
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
The car was suffering from misfiring from time to time due to a fairly brittle ignition harness so I replaced that for a Do-luck up rated one which fixed the misfire and made the car rev much smoother. I came across a twin core intercooler and said I'll have that, it dwarft the greddy one that was installed.
[IMG]
[/IMG]
The car went for a full respray a few weeks ago as the paint was starting to show its age. I had a carbon roof scoop fitted still not sure about it yet. Did a small bit of engine bay tidy up but I will eventually get around to pulling the lump out and sorting it properly. Tidied up the interior finally getting rid of some of those annoying rattles.
[/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG][IMG]
[/IMG]
Lovely car. Wouldn't be a fan of roof scoop personally
Monster of a car what's it drive like around town etc?
Wouldn't be a fan of the scoop either but other than that it's a thing of beauty, I love the kit.
Updated spec list
Engine:
Engine built by RK Tuning UK (RB30 Block & RB26 head)
Mapped by WCP
N1 Oil Pump.
Ported and polished head widened oil and water drains out by 1mm.
Cosworth 1.6mm HG.
Tomei 9.1 Lift cams.
Tomei adjustable cam gears.
Tomei adjustable fuel regulator.
Do-luck Enhanced ignition harness.
Splitfire Coilpacks.
S13 Aluminum radiator.
Twin Core Autobahn GTR Intercooler.
Oil & water cooled turbo by Extreme-Tuners.
HKS silent racer 3” straight exhaust.
Custom Downpipe by WCP.
Custom exhaust manifold by WCP.
DEI heat wrapped manifold and down pipe & turbo blanket.
46mm Tial wastegate with screamer pipe
Turbo Smart Dump Valve.
Apexi power intake filter.
Worsner Forged Pistons 86.5mm.
Worsner Rods H-Section Forged & shot peened.
ARP2000 rod bolts.
Rising sun performance custom baffled sump.
Mocal oil cooler.
ACL race bearings.
Greddy Iridium plugs.
800cc Injectors.
Oil Catch Tank.
320Ltr DeatschWerks Fuel Pump.
Battery relocated to the boot.
Interior & Electronics:
Link G4 ECU
Defi Advanced BF Gauges (Oil Temp/Press, Water Temp, Boost)
Race logic traction & launch control.
EBC digital dash.
Greddy OLED Boost controller.
Recaro SR3 x2 on bride super low rails.
Bride gear gaitor.
Nismo gear knob.
Nardi suede steering wheel & quick release boss.
Shite radio ☹️
Exterior:
Clearcorners LED headlights.
Custom body kit & De-spoilered.
Nismo clear repeaters.
DMAX smoked LED rear lights.
DMAX carbon bonnet with carbon bonnet dampers.
Carbon creations F1 style mirrors.
Driftworks carbon roof scoop.
Suspension Brakes & Wheels:
Driftworks coillovers
Driftworks rear camber control arms.
Driftworks tension rods.
Driftworks rear traction rods.
Driftworks rear toe rods.
Whiteline adjustable anti roll bars front and back.
Whiteline adjustable poly bushed droplinks.
Completely poly bushed using power flex bushes.
HEL braided brake lines
8 pot Brembos front & z32 setup on the rear.
Rota Grid Drifts 18 x 9.5 ET20 front 19 x 9.5 ET20 rear.
25mm spacers front.
Apexi front & rear strut braces.
Drivetrain:
R33 Gtst 2.5 gearbox
Helix paddle clutch
R32 GT-R differential rebuilt with custom setup by DeaneMsport.
Sent from my iPhone using Tapatalk
This car is savage, never seen it before fair play it looks different!
Tidy place to mount coolant over flow!
