Results 1 to 3 of 3
    Default dw geo master hubs??
    right lads making decisions last few days either to get the hubs choped and welded and all that carry on or get the dw hubs.. so i came to a desion to get the dw hubs.
    just want to is their much of ye lads running them?
    would i need to have adj lower arms?
    can i use standard tie rods and end?
    anyone have any feed back on these?
    di Member Driftma's Avatar
    Dungarvan,Co.Waterford
    you'll need s14 lower arms, not much of a need to get an adjustable lca. you'll need to use the longer tie rod setup you've got already and if you've got s13 coilovers you'll need to drill both shock to hub holes out to the same size as s14's and get 4 boltsand if your not 5 stud you'll need s14 wheel bearing hubs
    di Member bart's Avatar
    laois
    ian pm me....
