Results 1 to 5 of 5
Thread: sr wiring?
    Default sr wiring?
    Quick q on interior wiring. 180sx der Top have no dash lights. No park lights. No fuel pump. Car will crank away like mad.
    I checked all wires under wheel arch all is Good anyone have this prob b4
    di Member thedaggsy's Avatar
    Aug 2010
    Carlow 0857542948
    check ecu wiring harness..other than that your fuse board under the bonnet fuel pump fuse is der .. a dodgy connection in boot going to your fuel pump could cause it to blow. other than that i don't know
    Der's one born every day!
    AFM maybe had a prob before with nissan, bad connection car would not turn over. not sayin thats it but another possibility
    di Member jap scrap's Avatar
    There is a relay for the fuel pump in passengers foot well check that
    I d be checking your main pal fuses in the engine bay fuse box first ian,sounds like a ignition supply problem...they big 40/50/60 amp ones..
