Results 1 to 8 of 8
Thread: 6 point harrnes
    di Member rico180's Avatar
    Feb 2011
    Formally westmeath,currently calgary, Alberta .
    Default 6 point harrnes
    I recently just bought a 6 point harrnes , its a clip on to eye bolt job. I know that 2 eye bolts go in to the back seat and over my shoulders, and 2 at the drivers side for my waist, but where do I put the 2 that come up between my legs?? I got two plates with bolts tak on to them with the kit, do they get welded to the floor???
    Quote Originally Posted by rico180 View Post
    I'd say your gonna have to weld those plates on the floor for the eye bolts.
    Not a big deal to do really just put them behind the seat.
    If you don't have a welder just hit the spot with a grinder bring it back to metal and bring it to a welder for a 2 min job.
    Feb 2011
    Thanks for that johnbro, I was thinking that I had tha weld them, just wanted to make sure and get a second opinion ....
    wel man u cud also get 2 bits of angle iron drill out 10 or 12mm holes on one side to fix it to the front boltin points of seat and drill out other side big enough for ur harness to latch onto if ya know were im comin from? no welding involved
    Feb 2011
    Quote Originally Posted by B&G Extreme Drifting View Post
    Jayes ya , that would be dead handy. Thanks for that , deadly bit of info before I went grinding and welding
    Dec 2010
    I dont bother with the six eye bolts, just 4. I put the two that comes up between my legs into the same eye bolts that ya used for the two side straps
    Feb 2011
    This is really great advise and info. Thanks lads.
    ur welcome dude
