Cant be as its part of the alarm/immobilisor control module...what symptoms has it? Lift up the carpet in front of the passengers seat and you'll see a big black box...can almost guarantee that the floorwell is full of water and inside that box is the control module...commom problems you'll be lucky with just corroded terminals in the connectors but more than likely the control module will be damaged also,i normally pull em out replace whats neccessary and relocate the loom and module into the kicktrim..
