Results 1 to 10 of 12
    its not low enough!
    Apr 2010
    galway
    Default annoying 180sx clutch problem
    well lads my 180 has a stupid problem with clutch, i have checked the master cylinder an slave cylinder both perfect,
    the problem is its hard to select gears, if the car is hot sitting on the spot, with the clutch fully pressed, i try select 1st, i can feel it trying to engage gear, nearly knocking thru the prop, liek the clutch isnt disengaing fully, theres great bite in it no slip, am i right in thinking the pressure plate is gone weak? car was sitting for nearly a year cheers lads,
    Dec 2009
    yeah the pressure plate is getting weak, dont usually last long once this starts happening, a few weeks if your easy on it,
    [SIGPIC][/SIGPIC]
    its not low enough!
    Apr 2010
    galway
    Quote Originally Posted by raff View Post
    a few days so after the last few days driving haha sound!
    Dec 2009
    there will be a big bang someday when the centre goes through! and the peddle will hit the ground.. best order one now
    [SIGPIC][/SIGPIC]
    its not low enough!
    Apr 2010
    galway
    there was a new exeedy clutch put into it before it was parked up, i might drop box an see nick of friction plate, an see if i can get hold of a decent pressure plate
    make sure that clutch dampener is out they can cause it if not bled right
