Results 1 to 10 of 14
    Default need a diff welded
    my 1.8 is the r limited model eunos that supposedly came with the lsd as standard.
    was just servicing it there and tried spinnin wheels and theyre moving in different directions. maybe somebody changed the diff over time or something.
    so my guess is its the 1.8 open or viscous?
    its got nct next week so after that im gonna get it welded.
    anybody in dublin can do it?
    cheers
    clutch packs could also be massively worn causing similar effect.
    Can weld it for you if needs be, based in straffan. failing that, might have some other options for you like i used in trixtas mx5.
    di Member scallan's Avatar
    Sep 2011
    wexford
    All the mx5s came with torsen diffs and act like open d 1 wheel or all the wheels are off the ground Google it and ya should fond out a bit more
    Quote Originally Posted by will_c View Post
    his was shimmed was it?
    torsen any use for drifting or needs to be welded up?!
    Sep 2011
    wexford
    Ya that's it she should leave 2 marks in the dry up the road either I fond it hard to keep it locked somtimes and was thinking of changing to a welded. U should try pick up an open diff to weld cos a good lot of the torsens selling for around 300
    did the 1.6s come with open?
    mine doesnt lock too good.
    would rather a welder
    Sep 2011
    wexford
    Ya some of them do but ur better off trying get a 1.8 one as the 1.6 ones can cause problems
    Shim it I got a mate of mine to make up shims for Brian Egans mx5 and it done the trick pm me if y want his details
    is that will c that posted above?
