Results 1 to 3 of 3
    Default Diagnostic Query
    Hey all
    I have a 00 Lexus IS200 Sport
    I want to get a diagnostic check done
    Was goin buy plug and software myself
    And thought maybe someone in here has 1 and would be willing to check for me
    Gladly willing to pay
    I am in Drogheda, Co. Louth
    Can travel within reason
    All help appreciated
    Martin
    di Member twailbait's Avatar
    You could just bring to a main dealer and get them to do the diagnostics on it. its noly going to cost you 100quid and you'll know exactly whats wrong.
    Just because you get the computer program and plug yourself doesnt mean you'll be able to understand the fault code that it comes up with!
    For example, on some nissans notes, if the fault code comes up with front oxy sensor, its actually the rear one thats acting up.
    Or if its a cam or crank shaft sensor fault on a micra, then its actually a timing chain problem!
    So yopur better off just getting a main stealer to check it out and tell you whats wrong!
    di Member skelly's Avatar
    diagnostics arnt easy it not jus clearing fult codes and all is good i.e say u have a miss fire and it brings up and injector fault ye will have to know injector pulse rate and how much it can vary on idle and under load thats just an example get sumone that know what there doin to look at it what is the problem with the car anyway
