Right so the bro wants a bit more lock in the Hachi! whos the best for doing that job? that doesnt cost a bomb!
Get a extra lock spacer for the rack..it's 40 euro.."HM turbo " on ae86 sells them..Mamual rack and power steering knuckles and the jobs a goodin..quick and simple job that can down yourself!
Awesome!! whats the story with Modded Hubs for them?.. or anything like that
Alan Sinnott would be the best fella to talk to. Theres not a lot he hasn't modded on a ae86
Team WKD
there is no story,if you can turn a spanner you can put extra lock in yourself, that spacer hm turbo sells is a good job,just screw off the inner tie rod of the rack put this between them jobs a good un
its a similar mod to a battle version kit 2,there also easy enough found on ebay, theres no hubs on a twincam like a silvia just a steering arm/knuckle that bolts onto the bottom of the strut between it and the lower control arm,on most uk and some jap cars these are a longer type which give lighter slower steering but limit the amount of lock on the inside wheel on full lock so changing these for gtv/power steering knuckles gives quicker steering and extra lock,this along with a battle version kit2 or hm turbos kit will give copious lock that will mean some rubbing on the inner wing or lower control arm depending on,wheel size,offset,lca type,etc
theres inner tie rods that let the rack travel more into the rack housing for more lock, also great job but can be expensive and possibly not as much overall lock as a battleversion kit plus when the tie rod wears out which it will youll have an expensive outlay again to keep your lock
theres other stuff lads have experimented with but any of the above will get more lock than most will ever need,dmac is bringing out a few trick mods that go further to correct ackermann angle and stop the rack binding up under hard lock which is a characteristic of ae86s with big lock
your brother really needs to get himself on ae86irl!![]()
Thanks for the info dude!!.. im trying to get onto Ae86 irl using this same User name but to no avail! its been nearly 4 months or more since i signed up! i had to use a friends account to have a look on the site for info!
