Results 1 to 10 of 10
    Default hydro brake master cylinders????
    going buying a hydro shortly nut have no idea what size master cylinder to get get.
    i have the option of .625, .7 and .75 bore size.
    whats the difference in these when in use? what are you guys using???
    Drift Shed Doofer's Avatar
    Wexico
    .625 is the most commonly used in an Sbody Nissan from what I gather.. I've used a .625 in my Ps13 and it seems perfect for what I need it to do... Never tried any of the other sizes so I can't say anything about them
    FIND AND LIKE THE DRIFT SHED PAGE ON FACEBOOK.. THANKS !!
    Mar 2011
    carlow
    lad go buy a .7 or .75 as they are the job and only cost around 50quid in places like murry and so on for a propper girling cylinder
    the difference is night and day twoards the .625 comp brake ones
    the slightest tug on the E brake and its locked
    Member
    Oct 2011
    Loughrea Galway
    i had a .7 cylinder 1st and i found it a cunt 2 use took a good pull 2 lock the wheels. got a girling 625 then found it way better.
    cool dude thanks any idea what difference the sizes makes?
    what size wheels wer ya using dude?
    di Member Paddy drifter's Avatar
    Oct 2010
    inistioge co kilkenny
    i have a .625 in the bmw i think the difference is the .625 is the easyest to pull and the .7 upwards requires more effort and work to lock the wheels
    u just talk nice to me or ill tell john to make that cage out of timber and then we see who passes scrutiny
    Larger the piston, the more effort it will take to pull but will take less travel to lock the wheels.
    If your using a horizontal lever, I'd go with a .625 as a .75 might take too much work to pull it.
    If your using a vertical lever, you could use a larger cylinder as you'll have more strength pulling back towards you.
    Depends what brakes your using on the rear too really.
    I've been playing around with making a factory looking hydrualic handbrake and using a .625. Haven't tried it on my road car yet though as theres still fecking drums on that so hopefully will get round to that soon
    di Member Daraghs14a's Avatar
    Ennis
    I have a .7 on mine and I think I changing it also it will not lock the rear at all when the wheels have friction on the road but jack it up and it lock straight away so I know it's not air because brake are fine on the pedal . Everyone I ask say .625 also
    di Member bart's Avatar
    laois
    0.625 ive in stock........
    €40 for cylinder
