Results 1 to 4 of 4
    Dec 2010
    Default changin injector plugs
    Well lad i am putting sard 550cc injectors in my 180 when im changing around the plugs does it matter which way around the wires go??
    cork
    theres a tab on one side of the connector
    they will only go on one way
    Dec 2010
    ill be cuttin off the plugs for the sard plugs ill need to solder the wires
    cork
    polarity doesnt matter
    if you want,you can remove the pins from the old connectors and fit them to the new sard connectors.saves you cutting/soldering anything
