Results 1 to 10 of 10
    di Member johnjoeae86's Avatar
    Jan 2011
    meath
    Default spluttering and missing
    one the lads is setting up his s14 for mondello the weekend and doesn't think hell be making it car will rev and not miss but once its driving around 3 starts to splutter and serious lack in power checked all the intercooler and all is good but it seems like a boost problem, has this happened to anyone or would there be any other reason for this all advice is appriciated cheers!
    Nov 2011
    letterkenny
    sounds to me like its not getting the air feed and restricting itself, dirty filter or the likes, maby actuator not opening fully(saw this few times on intercooled diesels)same sorta system, or a vacuum pipe clogged or leaking, thats all i can think of someone will shed better light on it aneway
    Coil packs or fuel pump...!
    Quote Originally Posted by DaveZigen View Post
    It takes no talent, sacrifice or commitment to be a critic. Fact!
    Pro Driver
    plugs
    Jan 2011
    meath
    cheers lads tightened up everything last night and messed with a few vacumes and things were better but still serious lack of power at 3 not as bad as before but still not as much as there should be ......ill check the plugs and coilpacks and see does that help
    di Member NoelB's Avatar
    Sep 2010
    Vacuum pipes or coil packs id say
    cork
    inspect the plugs should be first thing to do
    black/brown/wet etc
    same thing happened me, threw in new fuel pump and she was grand, but check the other things first, plugs etc..
    Mar 2011
    kk
    Quote Originally Posted by mcdae86 View Post
    same here only 2 wks ago jus put in a bigger fuel pump and its perfect again
    di Member skelly's Avatar
    check the gap on the plugs and set to 0.5mm job oxo
