Results 1 to 5 of 5
Thread: s15 speedo
    di Member jamieae111's Avatar
    Nov 2010
    Default s15 speedo
    From what I understand, the S15 gets it speed signal from the ABS unit in the diff.
    thers a 5-Speed conversion on the car, just wondering is there a way to connect the speedo up to the speed signal off the gearbox, rather than the diff?
    The 5 speed conversion shouldn't really matter I don't think unless the prop had to be changed as well as the speed sensor is run off the input shaft into the diff??
    Nov 2010
    from what i can see the prop was changed aswel?
    is there a whole where the input shaft goes into the diff with a threaded 10 mm hole beside it??
    di Member Foxyfenlon's Avatar
    Dec 2011
    Wexford
    S15's take the speed signal from the abs sensor in the front of the diff,
    The speed sensor in a 5 speed box won't work the speedo as it's a different signal,
    Make sure the sensor is in the diff, might havebeen swapped for a different diff out of an s14,
    After that it's wiring or the clocks it's a complete head recker, i fixed a bad wire in my 15 clocks worked for a month and stopped again... Good luck
    Lots of info on (s15oc.com) free workshop manual download pdf
