What is the problem you are having? As above I just sleeved my Teins when I modded my hubs. If you modified the hubs the same way as I did then I certainley wouldn't be using the Japspeed ends.
No the hubs are quite different to the way you have yours done billy. I was originally supposed to get tein rods but I thought I could use with standard rods and save some money but turns out there not good enough
The standard tie rods have been sleeved and are 20 or 25mm longer iirc. Hitting the end of the rack, so need longer thread on the inner tie rod so more washers can be added giving more travel inside the rack. The difference in travel should be half inch with the longer thread and more washers allowing the extra couple of degree which the setup has been design for
Got any pics of the hubs just out of interest in anything R32 related?
Its funny you are running out of rack before lock, most modded hubs set-ups will hit something before the rack maxes out unless you have got some silly wide track or really weak offset wheels (which I doubt you do). But as I said I don't know what set-up you are running but would be cool to see it.
They allow the rack to move in 11mm on each side.
lengthen the track rod from 40mm to what ever length you want.
The advantage of these is you can use stock rods or tein rods ,witch is handy if you're looking for a spare @ an event.
Drop me a p.m if you're interested in a set.
you shouldnt need to let the tie rod into the rack more if the hubs are modified properly, if the rack wishbones and knuckles are all modified the right amount and the tie rods lengthened the right amount then you should only be useing 3/4's of the steering rack travel,
That's a diff story altogether I didn't know you had all these mods done. Do you need extended rods to correct this??
