Results 1 to 10 of 248
    Senior Member sideways-theonlyway's Avatar
    Dec 2011
    Longford
    Quote Originally Posted by Mac_C View Post
    Nice build man ! Good to see use getting stuck in !
    Ya dont need buckets of money to have fun drifting. Grass roots drifting FTW .
    As for the hydro , would ya not make your own ?
    Get down to the scrappy and get a mater cyclinder and a small bottle for the brake fluid .
    Or ya can buy a master cyclinder for a hydro out of most rally spares shop . Their about 40-50e .
    Weld up a wee box to bolt your master cyclinder to and a bit of threaded bar for a handle .
    Aye pull out the abs fuse out too .
    Edit. Mod`d the knuckles for extra lock on mine not too long ago well worth doing !
    Cut out 25mm off the knuckles and welded them on again , where the track rod end goes into the struts .
    And for extra camber cut the wishbones and welded a 35mm piece into it .
    cheers man, yeah must do that to the knuckles when I'm fitting the coilovers. The old stick welder will be out
    Donegal
    Quote Originally Posted by sideways-theonlyway View Post
    The very yock i used meself
Tags for this Thread
