Nice build man ! Good to see use getting stuck in !
Ya dont need buckets of money to have fun drifting. Grass roots drifting FTW .
As for the hydro , would ya not make your own ?
Get down to the scrappy and get a mater cyclinder and a small bottle for the brake fluid .
Or ya can buy a master cyclinder for a hydro out of most rally spares shop . Their about 40-50e .
Weld up a wee box to bolt your master cyclinder to and a bit of threaded bar for a handle .
Aye pull out the abs fuse out too .
Edit. Mod`d the knuckles for extra lock on mine not too long ago well worth doing !
Cut out 25mm off the knuckles and welded them on again , where the track rod end goes into the struts .
And for extra camber cut the wishbones and welded a 35mm piece into it .
