Ye it's grand plenty of time into the preparation makes for a good finish ! Several grades of wet and dry and work ur way upto about A 1000 grit or so ! Then nice build up of primer u can sand this lightly between coats if needed too then do the colour plenty of light coats is better than thick heavy ones. Leave plenty of time to dry proper or use a heat gun then lacquer! The prep is where most of time is best spent !
