Right so hears where the fun began....! After doing a bit of searching for s12 coilovers and parts i kinda realised that there non exsitant...! I was after buying a full s13 donar car with a few bits on it coilovers running gear exausts ect so I had all the gear there to bang a s13 rear end in it...! Turned out a lot harder than the front with everything being different...! So kinda the same job as putting 1 in a twincam...!
So i sized it up and did involve a bitta cutting even cutting the chasis in a couple of places...! Even the turrets were completly different so would have to make up new ones...! My motto is "fuck it go for it" so thats exactly what i did...! I get enjoyment outta hardship and i don't think anythings fun if its easy....![]()
Pic of the old setup in the car...!
And out on the ground...!
Sized it up...!
And started cutting....![]()
Bent a couple of pieces up to patch back in...!
Made up new mounts for the front section...!
And welded the bolt in...!
Made up the rear ones also...!
After a shitload of mesuring i welded them in...!
So went about cutting the old turrets out and cut the ones out of the donar car and try use em....! I think its gonna work but its all trial and error....!
Test fit...!
Cut the rest out and just tacked them in for the muinte....! Still a bit unsure about this...!
Bolted all my subrframe and arms up...! The 13 cambe arm woundn't work with the angle of the coilover so used s14 ones...! Its as far as I am but it all looks ok so far...!
Wheels on 2mor and hope 4 the best.....And yes serious overkill for a road car I know..... :P
