Results 1 to 10 of 14
    di Member Darenm's Avatar
    Sep 2010
    Default question on hicas "again"
    rite i no i had a thread up before about this but just want to b sure because im goin at it during the week
    rite iv a s13 subframe there to go in so i want 2 get rid of all the pipes can this be done or do i have to loop them to provent build up of pressure or any of that?
    next question is do i have to take out any fuses,solinoids ect....
    cheers in advance Daren
    MEATH
    Quote Originally Posted by Darenm View Post
    When i'm doing it i replace out the p/s pump and rack so you can remove the complete system
    Sep 2010
    wt pump and rack do ya use lad 33 is it??
    want to have to done rite so i dont run in to problems after
    MEATH
    Yeah usually use pump rack and lines from a r33. you do loose the speed sensitive steering but i like it a little heavier, more feel from it. all pretty interchangeable though ,think alan opel used all s13 parts and some say the s14 rack is a quicker rack
    This for a r32? iv done it if so, replace the steering rack wth a S13 & a built up RB housing / SR20 pump.. you need to compare the rb rack & s13, th rb rack has a machine finish on the inlet / outlet & the sr dosnt so you will have to either change the connections or get a good file & file it flat so it seals with the original bolts & copper washers. Hope it makes sence when you see the 2 racks side by side.
    Moonlight Kids™ dil's Avatar
    May 2010
    Kerry
    alan put an s13 subframe into mine so he should be able to tell you all you need to know!
    its not low enough!
    Apr 2010
    galway
    i looped them right at the p/s cooler line by drivers chassis leg! i didnt see the point in replacing pump an rack!
    Cork
    I agree ,no need to go replacing the pump or the rack.
    Another option is the take the pump apart "4bolts" + take out the metal vanes.
    You can then block the rear outlet on the pump + plug the return pipe to the power steering bottle.
    Sep 2010
    Quote Originally Posted by alan opel View Post
    Yes something that makes sence 2 me Haha
    Was it just 2 lines looped job done ya?
    Do I need 2 do anything else?
    MEATH
    I'd do the full job, much neater especially after swapping out the rear subframe, going that far and not changing the pump would bug me, daren have cusco lock out bars if you just want the handy option , even have a new pair of oem ball joints
