Results 1 to 8 of 8
Thread: Rb25 head
    Member Stevie-mc's Avatar
    Aug 2011
    Co Derry
    Default Rb25 head
    I bought a skyline on friday as a non runner. has a frost plug out, lad i bought it off said it happened last winter as he had no coolant in it. he has taken off the manifold to get at the frost plug and broke a manifold stud in the head and drill it out. Well i fired the car up this evening with the manifold still off and noticed oil running out the stud hole he must a drilled into the head. does anyone know would it be an oil feed or oil drain directly behind the front manifold stud on an rb25?
    sounds like he drilled straight into the head? Could be wrong tho,
    maybe tap it and seal it up with loctite?
    di Member Bennyk1122's Avatar
    Jul 2010
    give me a shout lad i have a head at the yard, you can take a look at it and it might give you an idea.
    Aug 2011
    Co Derry
    No bother lad it will let me see. you dont have a turbo or housing notice there mines is cracked must a been frost done that to.
    Dec 2009
    1j s are the same when i was rebuilding my engine and checked for oil pressure with the manifolds and oil studs still out oil came out throgh one of the exhausts stud holes , i was worried but when i looked at it one of the gallerys goes by the back of the hole, i checked another head here , and that was the same,i just used stud lock on that stud when putting it back in and its been fine since,
    [SIGPIC][/SIGPIC]
    Seen lots of idiots drilling into oilways on RB heads...WELD to the studs then screw them out dont drill!!!!!!!!!!!!!!
    di Member GTSr32's Avatar
    Yea sounding like what a ass of a engineering shop did to mine!
    End'd up scrapping the head!
    There are two drillings that run the length of the head, these two drilling are the oil feeds for the lifters.
    (most anoying bit is that I'm no mechine shop guy but when u got it back I was sick to see what they had done)
    Is it the top exhaust stud that snapped ?
    You may getaway with it if it's not to bad with the locktight
