Results 1 to 7 of 7
    Limerick
    Default Rollcage question on doorbars ?
    I see that when lads use fibreglass doors they install x-bars for protection but from looking at other RX8's built I've notice they take the below approach, is there any advantage to this ? Is it stronger or what is the motivation for this option ?
    Also is it necessary to brace the floor ?
    Some more pic's of the car :
    http://www.superstreetonline.com/fea.../photo_01.html
    Dec 2009
    Side impact protection is basically why there like that...! x bar would do for drifting as speeds aren't as high as other sports...!
    Quote Originally Posted by DaveZigen View Post
    It takes no talent, sacrifice or commitment to be a critic. Fact!
    Limerick
    Thanks Robbie... But if you had the option this method would be better ? Looking at cages alot recently and I know myself once I get a proper cage in her it won't see road, only track
    Cork
    An x-bar can take up more room in the door opening on some cars. If you think how high each end of the x would be on the A-pilllar and main hoops so that the lowest point of the 'x' would still offer enough side impact protection, there would be very little room to get into the car especially on an RX8 where the door opening is so long in relation to its height.
    Also from looking at the pics, the main hoop bends in fairly low down (only on my phone though so might b differnent on a bigger screen)
    Floor reinforced due to an RX8 having no B-pillar of course.
    Limerick
    I'm planning on putting the main hoop at the locking points of the rear door which essentially will be a false b pillar as such Well thats the plan anyways...
    Cork
    Arent the locking points ahead of the seat back though even in a road car with original seats?
    Could be pretty awkward fitting the main hoop and diagonal bars as well as the seats in a good position if your tall
    Limerick
    True lad, thankfully I'm a skinny git so I'll squeeze in I'm sure the lad doing it will be more than capable at designing up something cool.
