Results 1 to 6 of 6
Thread: m3 diff
    Junior Member
    Oct 2011
    Default m3 diff
    looking for bit of help lads was reading another thread about welded diff just there, on my m3 it one wheels every now and again when i dont want it to the bastard, its well able to hang tho still but would it be good idea to weld it or is it bad idea dont want to fuck the diff up and why does it do that thanks
    Donegal
    You cant weld the m3 lsd bud .
    You can get another medium case open diff and weld it or like ive done is put in smaller shims and 2 extra friction plates , leaves it basiclly a 2way .
    Open diff welded prob be the best job , your sure it will never one wheel with you then . And you can sell on your lsd .
    Mine is a great job never one wheels but still prob will change to a open diff welded in the future for piece of mind .
    May 2011
    castlefin co.donegal
    One wheels due to friction plates in the LSD
    Being fucked if ya think of them like mini clutches
    They jus ware away and need replaced Not a big job
    Ta get rebuilt deffo don't weld if it's a road car if
    It a track only car get a diff from an e34 525 and weld
    Her up and put it in your diff case
    Cork, Ireland
    As said above, replace the plates and she will be tight again. Mick Barry has em very cheap.
    TEAM MANFOOT
    Cork
    6 plate clutch pack and 40% ramp thrust plate mod is what you need
    The diffs are 2-way as standard, its just that they only have 25% lock and very low pre-load.
    Ive seen people try to weld LSDs though
    You can do it but you have to take it all apart so same work as rebuilding it... Iv seen one with just the holes for the oil filled up with oil and thrust plates welded in the open position!!!
    Junior Member
    Oct 2011
    thanks lads think ill get new plates for it then hopefully be grand
