Results 1 to 7 of 7
Thread: Help
    Default Help
    Ive a problem with a 200sx.when i turn a corner at any speed the power totally dies and then kicks back in after the corner.it happens when i try to kick it out aswell.its a standard lsd.i think its the diff any ideas??what would be the best diff to put in if it is.not a 2way as its a family car.cheers lads
    di Member Romo's Avatar
    Wicklow
    could be the fuel pump? does it die completley or just bog down?
    Quote Originally Posted by DeLab View Post
    when the foot is down the power bogs down then kicks back in.
    sounds like fuel starvation alright! or, could be a leaky boost pipe, has it a front mount? pipework could be flexing and leaking boost. its not the diff anyways
    Quote Originally Posted by twailbait View Post
    Im happy as long as every one acknowledges that you have a large quantity of retardation in you.
    seen some what same sympthoms before with a friends car fuel pump had come off the braket in the tank check that out first
    thanks for all the anwsers lads il check them out
    As above check the pump isn't off its mount and if it is still attached then make sure the 'sock' is still on the end of it.
