Page 1 of 6 123 ... LastLast
Results 1 to 10 of 55
    Default Mapping question re different boost setting /maps?
    Ok getting my car mapped. Road car so it will be a road map. I've seen people with 2 settings ie high and low boost, how are 2 maps saved/done? Is it possible on a nistune?
    And obviously I would need an electronic boost controller I guess!
    Any info lads? Need to start gathering parts ASAP!
    di Member twailbait's Avatar
    Get it mapped for high boost, and then just turn the boost down for the road to what ever you want , thats the way i've it done in the mazda and it works perfectly.
    Im using a gizmo controller and its piss easy to us and you can have 6 or so boost memories.
    cork
    you would only need two maps if you were running two different types of fuel.
    a tuner will map you car for high boost,and then low boost is the same map,just with less boost
    di Member hoopsbhoy's Avatar
    Sep 2010
    I know allot of people do it the above way, in my mind that cant be good at all, the car is basically mapped for say 1 bar and its running .7 dosnt seem ideal to me anyway.
    Pretty sure only place for a single map on nistune
    Yeh, pretty sure that just turning the boost down isn't the solution, yeh itl run less power, but it's not mapped for using less fue/boostl, so wouldn't realy be much more economical would it?! Im waiting on a reply off Robbie just wonderin if anyone knew details. Cheers Boyos
    Quote Originally Posted by twailbait View Post
    I'm not mad in buying a gizmo at all, too many bad reviews an the one in my 200sx broke and was nearly new!
    Ive had loads of good reviews on it and I've found it good!
    Although what boost controller you use wouldnt be the main issue!
    True that just don't want to have to replace one!
    cork
    the big issue that is being completely missed is:
    if you want to run less boost-just use your right foot as the variable
    if you dont want to be going flat out,dont sink the pedal to the carpet
    why would you want full throttle on low boost?
    economy?
    one map for 1 type of fuel is more than enough
    there isnt a need to be relying on a fancy boost controller to have loads of settings to suit your mood of driving
    if you want less boost,dont press the right hand pedal so hard.
    thats how NA pilots drive....
    Sorry, but above isny relevant. I know for a fact Robbie in tdp for example does road maps and Max power maps. I dont want max power all the time, sure I'm sure the road maps use less juice! Thanks for the input though!
