Results 1 to 9 of 9
    di Member haydn itr's Avatar
    Dec 2010
    Default mx5 conversion question
    have searched google cant find it exactly. iv found a mx5 for good money but its a 1.8 and i wana transfer the engine etc from trixtas drift car which i bought. also wana put in the diff brakes etc now his car was the 1.6 model. would it be a bad idea tryna put it into the 1.8? like are the looms easly changed and are the props etc different. any help lads?
    driftireland Staff - Moderator
    The diffs are the same, as timmy has a 1.8 diff in his mk1 and its a 1.6 engine the he said the 1.8 diffs are stronger. id imagine the boxes and props are the same then too. you would have to change the engine loom and ECU out anyway if your putting trixtas engine into it.
    Dec 2010
    Might just try and stay 1.6 ! Thanks for the info man
    Senior Member Dave's Avatar
    AS far as I know the 1.6 and 1.8 propshafts are different. Torsen diffs are meant to be stronger but Trixta's is a 1.6 rear end and he had no issues all season!
    Team Drift Shed haydomiata's Avatar
    Oct 2010
    wexico :)
    the only dif between the 1.6 and 1.8s are the 1.8 block is a lil longer afaik
    My signature picture was fricking huge - Admin
    click the image to see my facebook page
    Jan 2011
    Jan 2011
    I've a 1.8 LSD and 1.8 brakes in my 1990 1.6, I've also fitted a 1.8 clutch and flywheel in it too, most of the parts are interchangeable
    Jan 2011
    Dec 2010
    Thanks a lot lads
