Results 1 to 6 of 6
    Kilkenny
    Default SR20 powered 924
    Rite i have a 924 porsche in the shed and i was going to put a 944 turbo engine and running gear in it. I have got a 944 turbo engine and running gear for it but now im thinking of selling the engine and fitting a sr20 but going to use the 944 gearbox as it sits on the rear axle for 50/50 weight distribution. Its connected to the engine with a torque tube and im wondering how to connect that to the sr20 i.e use sr20 bell housing or the porsche bell housing. Reason for doing this is the porsche parts are a crazy price and not easily found. What would ye think is the best way to go about it. Would like to use a sr clutch as it would make it a bit cheaper again. Going to use this as a road car aswell as ill get vintage tax and insurance. Its just an idea for now but if people think it could be done ill be putting the engine up for sale on egay. Attached is a pic of what the torque tube looks like. Any ideas appreciated.
    Pro Driver
    anything can be done
    The way we would tackle it would prob mod a sr bellhousing to bolt you your 4 bolt t tube and use the porsche clutch dick with a correct spigot bearing and use the sr flywheel and pressure plate
    Kilkenny
    Quote Originally Posted by D McNamara View Post
    Thanks Darren .Ya it all sounds so easy ha. Was looking at a clutch i could use but porsche ones are fairly saucy but some ford ,Mitsubishi and Mazda ones are the same size i think so that might be a cheaper option, 1"x23 spline. I think i might have to do some more research. Thanks for the advice appreciate it. Looking to build it for handy money and mod the engine after. The 924s came fully galvanised from the factory so only bit of rust is under the battery tray so its a pitty not to use the shell and with insurance gone crazy the vintage insurance is a cheap option.
    Roscommon/Galway
    Sounds very interesting you should start a thread in the projects section
    sr20 + porsche = win idea!
    Kilkenny
    Quote Originally Posted by Blacklimited View Post
    This won't be happening for awhile need to finish building my shed first and then find some money as always. Ill be putting up a thread when i start don't worrie
