Results 1 to 4 of 4
    Feb 2011
    Co. Fermanagh
    Default Fitting a 2 way...
    I'm going to to have a go at fitting the 2 way TRD I got off chuck today. I have to remove the casing at take he innards of mine out and install the 2 way into my casing, is there anything I should know or any handy tips yis have as I havent done it before. Cheers lads.
    Feb 2011
    Co. Fermanagh
    Bump for this lads, I'm ony startin it here, should the two driveshafts come away from the side of the diff casing when the 6 hex head bolts are removed? I dont want to beat too much at it a I'm not sure how it comes apart... Any help much appreciated..
    di Member Shorley86's Avatar
    Sep 2010
    nenagh co tipp
    after you take out the 6 bolts you might have to give it a small tap of a hammer before they seperate. drain all the oil. and drop the diff from the car. easy to do once its out.
    Feb 2011
    Co. Fermanagh
    Quote Originally Posted by Shorley86 View Post
    I was tappin for a while and was Gettin nowhere, so a bit more persuasion and off they came, just didn't want to beat at them too much when I wasn't sure now they came off. Cheers anyway
