rite this is wrecking my head i have no back lights, number plate lights, speedo lights or parks
head lights are working as they should
are these all part of a relay or am i in shit wit wiring??
might be a fuse...
Just checked all fuses under the dash and all seem 2 b fine il check under the bonnet 2m
they all work off the same fuse, check the fuse, does your radio work? the illumination wire for the radio alot of people think is an earth, and when u turn lights on, boom it blows the fuse!
My r32 developed a problem similar, I took apart the switch that turns them on, inside there are metal toggles, I cleaned and sanded the connection tips as best I could and it was 100%
der is a fuse under the bonnett for these as well as one under the dash!
had the same problem and it was a fuse, i would check them again lad
